Upgrade CCM cluster to 3.3.3 version problem
mborgul
Hello
Today I was trying to upgrade our CCM Call Manager Cluster from 3.3.2 to 3.3.3 version. Unfortunately following problem has occured.
When I was trying upgrade subscriber (after I install CCM 3.3.3 on publisher) I got following error message:
Failure occurred trying to get DBNAME value from registry. Aborting Cisco CallManager installation.
I suppose that I have made mistake rebooting publisher before upgrading subscriber. I have noticed in SQL enterprise manager that on publisher there is two databases : CCM300 and CCM301.
Only CCM301 is published
On subscriber there is only subscription of CCM300. Now I see that IP telephony system works but I can't proceed instalation on subscriber.
Has anybody had any experience regarding that problem ?
If you need more information I will provide it to you as soon as possible
Thanks in advance
Michal Borgul
5 Replies 5
I had the same exact problem when upgrading. I had to call TAC and they had to get into the registry of the subscriber to point it to the right database. I wish I could tell you more, but they seemed to know exactly what the problem was because it is a known problem when performing the upgrade to 3.3.3.
I got information that I should create dbname.ini and backup.ini files on subscriber. I have done this but It doesn't solve problem. I made additionally changes to Dbname Key in registry from CCM300 to CCM301. But it doesn't help too....
Michal Borgul
I have some additional information.
I have noticed that Cisco tool called
Database Helper shows wrong name assigned to subscriber.
But I have checked LMHOSTS file and there is correct entries for exmaple:
10.81.1.8 TORCCM01 -our publisher
10.81.1.9 TORCCM02 -our subscriber
Database Helper shows following information
TORCCM01 10.81.1.8
TORCCM01 10 81.1.9
There is a following comment
Duplicate server found. Don't process.
It seems that it could be due to name resolution problem. But I see that LMhosts file is configured properly. In our CCM configuration we use IP addreses instead of DNS names.
So I hope maybe that information is a key to solve that problem
Best regards,
Michal
I`m having the same problem with my Subscriber, My Publisher did it until the 5th installation.
Has anyone got this working yet?
I'm also having the same problem. I have run DBL Helper and I have 2 problems. I have the same as ref above, duplicate name but I cannot find where the duplicate name is, also I have deleted an old subscriber and re built it and in the DNS part it is showing up as the new IP but the old name. I have checked the lmhosts file and when I run the nbtstat -c I get the correct names.
Any ideas?
